When a subarray is created, the data is copied from the origin-array.
The LabVIEW Compiler does not recognise if the subarray data is then only read.
It would be a major improvement for memory and even CPU usage if the compiler recognised that some part of the array is only read and pass only a reference to that part of the array in the memory.
