Minions
Pass-through Register
Status: Declined
National Instruments will not be implementing this idea. See the idea discussion thread for more information.
I was thinking that it would be nice if there was a default connection of a pass-through register.  Similar to the shift register only here it would pass the input to the output by default rather than having to wire each case.  If there is a wire into the output, the default connection is NOT selected.  In the snippet, both the top and the bottom outputs are the same for this case.  It would make for cleaner looking block diagrams if the only thing happening in a particular case is the wiring of an input to an output.Pass-thru Register.png
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
11 Comments
Darren
Proven Zealot
Status changed to: Declined
