13 | |
11 | |
3 | |
3 | |
3 |
Selecting the browse button of a path control of a VI under a real-time target brings up the file system of the host computer. This is completely useless and misleading. If you select any file or directory with this, it won't work when you run the VI.
I propose changing the behavior that selecting browse (on a path control) of a VI under a real-time target to show the file system of the remote target. I've seen X controls to do this before. In fact, Drivven has one. If not, I would at least remove the browse button.
