When we try to replace a small function in the function palette its easy... But while trying to replace a VI which is inside some sub palettes and sub palettes its really time taking..
So while replacing a VI its good to pin the function palette and select the item for replacing.
I hope this has not been posted earlier.
Existing
Suggested
