13 | |
11 | |
3 | |
3 | |
3 |
I suggest that NI clearly mark those functions in IMAQ that require a run-time license. Perhaps color their icons pink or some noticeable color. There is a lot of misinformation in NI technical support regarding this issue. I wasted a lot of time developing an IMAQ program and found out later that it required a run-time license that my client did not want to buy. So, I had to rework the code to eliminate those functions that require a run-time license.
admin note: Invalid link has been removed.
