10 | |
3 | |
2 | |
2 | |
2 |
On Plot Attribute Change event, the cluster structure should match with the group of properties such that we could pass it as is and re-use it when we need to re-apply all properties. Inside the property node there should be a section Plot.Attributes.All Elements that would be identical to the cluster returned by the event.
Also worth mention that Plot.Visible is not part of the cluster but the event is triggered when user toggles the plot visibility. Strangely the Plot.Name can also be edited by user but that doesn't trigger the event.
I wonder if it's a missing feature or more like a design flaw.
