When I need to pass a data from a loop to another I need to create an indicator and local variables which create copies in memory for each variables. So we have at least 3 copies in memory for the same data. One for the wire itself, one for the indicator and one for the local variable. Why there is no kind of pointers which LabVIEW could handle from under the hood with the wire's memory adress. Imagine something like that. Then we don't need to use a hidden indicator only for data passing.
This example doesn't look very clever but you can see what I mean.
