Sometimes debugging re-entrant VIs is painful. Its possible but slightly messy. It would be great atleast if a probe is offered that shows the control and indicator values when the VI is hovered over while it is being used as a subVI in another VI. Please see the picture below to understand what I am trying to say. I think it will help in quick probing of the values together.
