11 | |
7 | |
3 | |
3 | |
2 |
I would like to propose the inclusion of the possible errors to the help menu of each function.
If you are new to LabVIEW or have to work with something you don't know, it would be nice to see all the possible errors, so that you can handle them appropriately. Also it is easy to forget an unusual error or one that is so common that one hardly notices it anymore (e.g. timeout, reading non existent array elements or division by 0).
This information is included in the APIs of other programming languages, e.g. Java, as well and saves a lot of time in searching and testing for an exotic error.
