Quiztus2
Pre-navigate Add File... dialog to folder containing .lvclass or .lvlib
Status: New
When adding a file via the project tree to a .lvlib or .lvclass, it is highly likely that the file is located in the same folder as the corresponding .lvclass. For .lvlib, the file is either in the same folder or one level deeper.
When using the right-click menu Add File... on a .lvclass or .lvlib, the Select File to Open dialog should automatically navigate to the folder containing the .lvclass or .lvlib.
Currently, it navigates to the previously used folder instead.
This should immediately navigate to the folder containing Cell.lvclass.
Actor Framework
