6 | |
2 | |
2 | |
2 | |
1 |
When logging errors to a text file, I would like to see the latest error that occurred rather then the first error to ever happen and have to scroll to the bottom of the file and view the latest error (I know first world problems). If there was a way to place the cursor at the start of the first line on a text file and enter the data shifting all the original data over/down, that would be helpful. Currently when the cursor is placed at the start of the file it deletes the data as it is overwritten, if 25 characters is being written, then the first 25 characters of the text file is overwritten.
It is possible to read the entire file and concatenate the new data at string 0 with the old data at string 1, but if the file gets large (we don't clean our files / want to remove error data) this can become cumbersome and CPU consuming.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019RNsSAM&l=en-US - Dated 7 July 2022, states that prepend can not happen the way I would like.
