I want to have the possibility to use a probe directly on an iteration terminal.
When using a loop (for- and while-) I sometimes would like to see how many iterations that have past since I started. This is easily obtained by using an indicator connected to the iteration terminal or using a probe on a wire from it, but if I forget to create an indicator and I don't use a wire from the terminal I think it would be great to just right-click on the iteration terminal and create a probe.
