I often want to see if a while or for loop is running by watching the loop iterator. Now I have to stop the program, wire the loop iterator to the border of the loop, add a probe to the wire and run the program.
It would be great that I could right click the loop iterator and add a probe while a program is running.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Probes-for-Loop-Iteration/idi-p/917379
