Brunninge
Probe with array
Status: Already Implemented
Available in LabVIEW 2015 and later. When you resize the probe window with an array, the array display is resized to show more elements.
When you have a probe to se the data in an array, you se all elements in one row (in the Value column) and just one element in the Probe Display area. If you have a large array, it is difficult to get a good overview.
My suggestion is that in the part of the probe window called Probe Display, you should be able to pull the bottom right corner and see several elements simultaneously.
An extra feature would be to also show the array size anywhere in the probe window.
6 Comments
GuenterMueller
Active Participant
You can create a custom probe that covers your demands regarding the appearance of this probe.
parthabe
Trusted Enthusiast
In LV 2015, 2D array inside the Probe Display auto-expands as you resize the Probe Watch Window by dragging the right bottom corner.
- Partha ( CLD until Oct 2027 🙂 )
GuenterMueller
Active Participant
Darren will be happy to mark it as "already implemented".
I am currently using LabVIEW <= 2014, so I have wait for benefiting from this feature ...
Darren
Proven Zealot
Status changed to: Already Implemented
parthabe
Trusted Enthusiast
I installed LV 2015 SP1 last week & so got to see this new feature implemented there, and I just stumbled upon this thread y'day. Smiley Happy
