Intensity graph didn't process NaN values like other graphs.
For example, in chart or waweform graph NaN values are represented by a blank (or missing) point.
When we use intensity graph NaN values are represented as values less than low color Value. I think it's not a correct representation and it could produce misunderstandings for user.
I'd like that color for NaN value could be selected and customized by the user.
I propose something like that :
