I have a little complain about the product (LabVIEW or other) installer.
Since most of the time the installation lasts for a (very long) while, I still continue to work on my computer (i.e.: writing docs).
Because some new install window pops up regularly and unpredictably, taking the focus, and because the default cancel button is active and it happens just when I type the enter key in my doc, the installation just get cancelled. With the help of Murphy, this happens after one hour of process without the knowledge of what has really been installed so far. So just, to be sure I can just restart the process.
This happened not only once, It’s the 2nd time this week, one time during setup from DVD and the second while updating from the updater service.
Would it be possible to set the focus on something else than the cancel button, not let it as the default button and add a confirmation dialog to the cancel request ?
Best Regards
I don't believe this is an issue anymore, now that we install with NI Package Manager.
