11 | |
8 | |
3 | |
3 | |
2 |
I am not happy when I inherit legacy code where VIs have inconsistent alignment grid options, as shown in the image below.
My team has coding standards we follow, and those standards include alignment grid options. It is labor-intensive to change alignment grid options on legacy VIs because you have to do it by hand, and clicks quickly add up. I wish I could automate such changes.
I’d like to see a few new properties to expose settings available in the editor, as shown below.
These properties need to support both read and write.
Available in LabVIEW 2019. There are two new properties of the VI class: Block Diagram Window:Alignment Grid Size and Front Panel Window:Alignment Grid Size.
