JackDunaway
Programmatic Manipulation of Object Layer (z-order)
Status: New
Unfortunately, we ran into issues with rearranging the Z-order of controls at run-time, and have decided to pause development of this feature.
I would like to be able to change the z-order of FP Objects programmatically. For starters, I envision the following properties:
  1. Layer - Explicitly sets the z-order layer in which an object resides.
  2. Promote/Demote - Implicitly sets z-order layer by -1 or +1 (assuming Layer 0 is frontmost)
  3. Send to Back/Send to Front - Explicitly sets z-order to the foremost or rearmost layer
  4. (Optional) Container property "Layers" - Returns an array of all layer indices currently in use by the container (Page, Panel, Cluster, etc.)
  5. (Optional) Container method "Layer.Objects" - Returns array of references to all objects on a layer
Question at this point: can more than one object reside on a layer, or should each object represent a discrete z-order? Does changing the z-order of one object likewise affect the z-order of other objects? Discuss in the comments.
17 Comments
JonP
The most common case, as in the OP's example, is probably that you want to swap the z-position of 2 controls. If so this could be done in a single call to a VI method passing in references to the two controls. There is no need to know anything about "layer" numbers, internally the existing z number of the 2 controls is just swapped.
You would also need an interface to ask if control ref A is in front of ref B in order to detect whether or not to swap them.
Christina_R
Active Participant
Status changed to: In Development
Christina Rogers
wiebe@CARYA
Knight of NI
Will this new feature work only when VIs are idle, or also when VIs are running?
Changing this for running VIs would definitely open possibilities.
Christina_R
Active Participant
The feature under development is inspired by this Idea, but not exactly the solution that was proposed. It will, however, enable you to change the z-order of controls on running VIs!
Unfortunately, though, it's likely that rearranging the z-order of controls within a cluster will not be included with this feature's initial release. We're planning to support panes and tab control pages.
Christina Rogers
Christina_R
Active Participant
Status changed to: New
Christina Rogers
Andi_S
Are there any plans or activities to proceed with the development of this feature?
wiebe@CARYA
Knight of NI
It's actually there in LV23Q3 (maybe even Q1) and higher, but as a private (brown) node. So as Christina mentioned, there's probably something wrong.
Last I tried there wasn't much that wasn't working, but IIRC had to feed the node all controls (not just the ones to move to front\back\forward\backward).
I could really use this feature too. Without a finished solution I'd settle for a list of caveats on a partially finished solution.
