The idea is to enable read access to the "Error List" programmatically (scripting) in LabVIEW.
> is there a way to find out the error messages using scripting ?
No.
+1 for headless/unattended use like CI pipelines. If there's a build error my script should be able to tell the developer if the code even compiles in development+why not.
+1. Any functionality that increases the observability of LabVIEW codebases and/or of the LabVIEW editor is welcome.
