It would be useful if you could change the numeric (FXP) information (signed, word length, integer word length) of a data type during run time.
Since all diagram types must be known at compile time, there is no way to dynamically decide the type of a wire. Variants are the only way to handle dynamic types at runtime. However, variants do not expose any way to take data of one type and convert it to a different type within the variant.
This functionality would be useful for example, if you use the 'Get Fixed-Point Information - NI VI' to extract fixed-point numeric (FXP) information from a data type stored in a variant, and then could use that information to caste it into a variant. This is solved in the image attached using a case structure, but this is not a very elegant solution.
