There should be a Browse button on the right click menu for front panel items as it is on the block diagram right click menu.
Make the search in Browse traverse the displayed property tree instead of the type specialization.
Otherwise you won't find Increment when searching the graph's properties:
Just display the hierarchy with the results like:
X Scale::Range::Increment
Y Scale::Range::Increment
