6 | |
6 | |
3 | |
2 | |
2 |
Provide a selectable Name Format for the Disabled Property Node Constant. I understand making the constant an enumerator to provide code documentation. It would be nice to select the Initials by Function to save wiring diagram space (see below).
Do you ever disable controls, I do it all the time and I’m sure you’ve done this.
I created a VI to do just that and save wiring diagram space.
I’ve attached this VI and a Polymorphic VI version of the Disabled Property Node Constant. Use this Polymorphic VI to substitute the property node constant with an initial by function icon. This will reduce block diagram space while still providing limited code documentation. Select between polymorphic instances E) Enabled, D) Disabled and G) Disabled and Grayed Out, by function just as you would the constant.
