 DanyAllard
			DanyAllard
		 on
		06-04-2009
		04:19 PM
			36 Comments (36 New)
			 on
		06-04-2009
		04:19 PM
		Let’s take the Value Changed from OpenG, This polymorphic as 30+ VIs to support all data type and array size up to 2D. But basically it’s the same VI for all data type.
Available in LabVIEW 2017. Use Malleable VIs (.vim files) to define a generic implementation for a single subVI that will adapt to multiple wired input data types.
