Dataflow_G
Provide a tooltip for Recent Project entries to see project path
Status: New
If there are multiple projects with the same name listed in the Recent Projects list, there's no way to determine which is which:
The idea is to display a tooltip showing the full path of the project when hovering over an entry.
5 Comments
crossrulz
Knight of NI
There is a tool tip in the list on the Getting Started Window.  But I can't say I have ever seen a tool tip for a menu item in any application.
JÞB
Knight of NI
Yes, the Getting Started Window ( menu, edit, show GSW) has that!  Any text editor  can open your LabVIEW.INI.
But, why do you have multiple projects with the same name?  SCC.
wiebe@CARYA
Knight of NI
Comparing branches\revisions simultaneously. Doesn't happen that often, but it happens.
Dataflow_G
I've seen it in Inkscape, which is the inspiration for this idea:
This was my use case. I had also saved the project for a previous version, which was then opened for a quick sanity check. This led to three visually identical project listings in Recent Projects.
wiebe@CARYA
Knight of NI
I'll kudo it.
But if it is implemented, I want it for "Recent files" too.
Spoiler
I think it will appear in the "Recent files" menu more often, as I often edit VIs with the same name, for instance when implementing a method in all children of a class. Then the VI name doesn't mean anything, without the class name. And the class name will get replaced by "…".
