When you drop a VI on the block diagram it's becomes statically linked to the calling VI. If instead you wanted to call the same VI dynamically (without creating an edit-time dependency by using a Static VI Reference) you'd have to change the code to, instead, open the sub VI's ref by path, create a type specifier and then wire the reference to a Call by Reference node.
Why not instead just provide the option to call a given sub VI dynamically by right clicking on the sub VI itself? I'm picturing a right-click menu that has two options:
If "Dynamic Call" were selected, all the steps to convert the call to dynamic would be handled would be handled by the IDE/compiler without the developer having to actively modify the block diagram. The IDE has 90% the information to make this happen, right? And the missing information could be provided by an options dialog if necessary (e.g. synchronous vs asynchronous call, run as sub VI vs top-level).
There should probably be some sort of visual indicator on the BD that the sub VI is being called statically vs dynamically.
Idea re-opened based on feedback in the idea discussion thread
