13 | |
11 | |
3 | |
3 | |
3 |
It would be helpful if the LabVIEW Python node natively supported Python dictionaries as LabVIEW Maps. This would make it simpler/easier to support a frequently use Python structure. You can work around but you have to do extra data preparation/formatting in both LabVIEW & Python. It would be nice if the node handled that converting to list of tuples and building the LabVIEW map or vice versa for us.
