LabVIEW 2017 ships with an example project, Channel Message Handler.lvproj, which provides a starting point for a QMH using channel wires. However, it would be neat to have a more sophisticated sample project (something on par with the Continuous Measurement and Logging sample project) which uses channel wires as opposed to the traditional queue approach.
