In the documentation of the Divide Quaternions function of the Quaternion subpalette of the Robotic Arm subpalette of the Robotics Module, the documentation fails to mention whether, given that we are dividing quaternion by y, whether the result is (quaternion * y^(-1)) or (y^(-1) * quaternion). As these two are each others' negatives, this seems important.
