I think it would be really useful to have a Quick Drop shortcut installed by default that toggles label visibility for selected items. I know you can select multiple objects and right click> Visible items> Label but this takes me several seconds.
How I imagine it would work
Select GObjects on front panel or block diagram --> Ctrl+space, Ctrl+L --> label appears if it wasn't visible or disappears if it was visible.
If multiple items selected with a mixture of visible and non-visible labels, use the same logic as what happens when you try to embolden partially bolded text : toggle all to the opposite of the most frequent state.
I might write something that does this, but it would be really great if it was standard. 🙂
