I have some quick drop shortcuts set up, w gives me a while loop, c gives me a case structure etc.
If I want a while loop I have to press ctrl+space, press w, click on the block diagram, and then I can draw a while loop.
Instead of doing all that, I want to just press w and have the cursor change so that I can draw a while loop.
Pressing the keys on the BD does not do anything, unless you are editing text, so it isn't interfering with anything else.
Also, it would be nice to customize the keys, for example: set i = index array, e = event structure.
