Most programming languages have a Mod or Modulo function which is equal to the remainder after a division. LabVIEW has the Quotient and Remainder function in the palette which is equivalent, but most customers new to LabVIEW come in looking for a Mod function and cannot find it. LabVIEW should probably have this as an alternate function or at least put tags on the Quotient/Remainder function so that it comes up when users search for Mod or Modulo.
