I suggest that radix is always visible when the numeric display format is other than decimal. Is this number decimal for instance?:
Well, it was hex:
Basically you'd know that if there isn't a radix visible, then the number is decimal. It should still be possible to show radix for decimal numbers as well. This should be the case for both constants and controls/indicators.
Just one of those little things that would enforce a minimum of documentation.
Cheers,
Steen
