8 | |
3 | |
3 | |
2 | |
2 |
Local/global/Shared variables or properties nodes (that are read/writeable) are usually placed in read mode.
For Power users it would be great if by holding e.g. the Strg.-Key the local variable or properties are placed in write mode. Also a good idea would be that the node adapts to the wire (input or output), but this idea is already in the idea exchange.
