| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
With text based languages, the For Loop has a programmable starting index, stopping index, and step size. With Labview, the starting index is always zero and the step size is always 1. It is not changeable. I would like to see Labview have a real For Loop where there would be three terminals inside the For Loop that can be set by the user. One terminal for initial value (starting index), one for final value (stopping index), and one for step size. This would be of great value to all Labview programmers. Of course the terminals can be much smaller than what is displayed in the picture. One or two letter terminals, such as ST for start, SP for stop, and SZ for step size would do fine. (or N for initial value, F for fnal value, and S for step size). The real for loop should be capable of going in a negative direction, like starting at 10, ending at -10, with a step size of -2.
