3 | |
3 | |
2 | |
2 | |
1 |
It'd be quite helpful if you could have several search result windows (or tabs) since it's not that uncommon that you e.g. search for some text and want to keep that list of VIs while searching for something else. Especially when the projects get into several thousand VIs it takes a while to do the search, thus i prefer to not do it again ...
Allow multiple instances of "Search Results" window - NI Community
