13 | |
7 | |
3 | |
3 | |
3 |
As described here, the Event Structure has a few interface issues. One of which is that the "Rearrange Case" Dialog window is not resizable, and the "Complete selector string" has no scrollbar:
If you have dozens of cases, some of which may contain a dozen different events, this is a nightmare to use.
Don't get me started on the way you can rearrange cases only by dragging and dropping one at a time (ever heard of alphabetical sorting for instance?)!
Thanks for reading.
