Sometimes when dealing with the Bundle/Unbundle by Name nodes, I start with more elements than I actually end up using. Then, my block diagram looks something like the following:
Maybe I'm just lazy, but I really hate removing each unused item from the Bundle/Unbundle by Name node over and over. Right click on unused element, click "Remove Element", Right click on next unused element, click "Remove Element", etc... Ugh!
So I'm suggesting a "Remove Unused Elements" when you right click on a Bundle/Unbundle by Name nodes. With this option, right clicking on one of these nodes would look like this (emphasis added
The result of this operation would look something like this:
Now I can spend my time coding instead of getting rid of individual elements!
Thoughts?
