Many of the VIs or projects that I create are just a learning experiment to get things in the right direction. My startup screen is overflowing with junk files that I never need to see again. I would like a "right click --> remove item" when you hover over junk files in the right pane of the LabVIEW startup splash screen.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Remove-entries-from-quot-most-recently-used-quot-secti...
