8 | |
6 | |
5 | |
4 | |
4 |
Renaming files with F2 or the context menue entry "rename" is easy - as long as the file is a LabView or NI-File. But if it is just a simple *.txt, *.pdf, ... file it is not possible. Please add this function! - thanks.
