matt.baker
Reorder controls in cluster - keep scrollbar enabled
Status: Declined
Keep the front panel scrollbars enabled when reordering contols in a cluster. At the moment the scrollbars are overlayed/disabled when enetering this mode which makes it difficult to reorganise large clusters.
Y U NO SCROLL
9 Comments
JB
Trusted Enthusiast
Trusted Enthusiast
I don't remember the behavior of previous versions of LV but with the recent ones, the scrollbars are enabled during the reordering.
Which version of LV do you use ?
Spoiler
According to your screen captures at least LV 8.20.
matt.baker
Active Participant
JB,
I am using LV2013 SP1 Patch f2 32bit
I didn't realise it should have them enabled. What version of LV are you using?
wiebe@CARYA
Knight of NI
In LV7.1, they are not darkened, nor disabled.
This changed between 7.1 and 8.2.1. Since then they are enabled, but darkened.
It probably changed in 8.0, but I try very hard to ban every trace evidence of 8.0's existence, so I can't test it.
The darkening is confusing. Perhaps this is a bug?
matt.baker
Active Participant
You are, of course, both right - scrolling is enabled! I got it wrong.
The thing that fooled me was the grey overlay along with the cursor not changing from the reordering cursor when hovering over the scrollbar. Bad design, but the functionality is there.
RavensFan
Knight of NI
Matt,
Your image no longer shows up in the idea.  It is now just a red X.  (I saw it earlier today, so I know it did exist and what it looked like.)
Please don't tell me you deleted the image out of your image library.
matt.baker
Active Participant
I tried to update the idea post, but it wouldn't let me. It would be great if the original poster could modify their ideas at any time in the future with a change history. Yes, unfortunately I have to admit I deleted the image from my library after failing to edit my original idea post. Apologises.
matt.baker
Active Participant
If someone can give me permission to edit my idea, I'd be happy to re add/modify the image based on latest findings/my mistake. Thanks
wiebe@CARYA
Knight of NI
Matt,
Id would be very confusing to read all the replies if the original idea changed. I often want to edit mistakes, but when replies to or kudo's, it's just not possible.
Also it would be a bad idea. One could change a post with much kudo's, and chnge the idea to a bad one. The kudo's would now appear to apply to the bad idea.
Darren
Proven Zealot
Status changed to: Declined
