McQuillan
Replace Malleable VI with Static VI Instance
Status: New
I really like using VIMs; however, I have been having a lot of issues when saving for previous versions / VIM based bugs.
What I would like is a right-click (under the advanced tag) to convert VIM to VI copy (which you could then save) and a 'tools>Advanced>replace all VIM instances in the project' tool.
I attempted to make this myself, but it turns out the 'Replace' scripting method doesn't work with VIMs and I don't really want to go down the route of deleting, placing, rewiring.
So either, could I suggest creating the tool, or providing the scripting functions for us to create the tool.
NB: This is the proof of concept I was trying out to change VIMs to VIs:
Order of operation:
  1. Get a reference to SubVIs and filter for VIMs
  2. Create a copy of the VIM and save as a VI
  3. Replace VIM with new VI
3 Comments
crossrulz
Knight of NI
I view this as a similar thing to "Open Front Panel" on an Express VI.  But I am having trouble coming up with another reason other than the Save For Previous.
McQuillan
Active Participant
I don't know if this has been fixed now (I hope so), but there was/is a bug when building VIPs (using vipm) when your VIM was in a class. There also seems to be bugs when sharing the source code of the VIM not finding the correct instance - I can't remember the exact cause, but it meant I had to manually convert the vim to a vi (hence attempting the scripting tool).
McQuillan
Active Participant
I ran into an issue I have had in the past, but it popped up again. I think I've only had this issue with 'Is Value Changed.vim'. I'm not sure what is causing this to happen, however, this is one of the reasons I would like to be able to convert from vim to vi.
Is Value Changed.vim not foundIs Value Changed.vim not found
