If LabVIEW shows coercion dots, I usually insert the corresponding conversion function (as recommended).
Some times it is a little bit annoying to seek the correct function. Especially because I know that LabVIEW knows the desired data type. If I connect the wire to a VI I have to look up the correct type in the context help. Afterwards I have to seek and insert the corresponding conversion function.
I think that LabVIEW should support this replacement a little bit more.
I suggest an interactive support:
a) If you click on the coercion dot LabVIEW should show a little dialogue and suppose to insert the corresponding conversion function.
b) If you right click on the corresponding wire the context menu should purpose the corresponding conversion function more directly (see pictures).
New:
Old:
