10 | |
3 | |
2 | |
2 | |
2 |
If I have a TypeDef cluster in my block diagram, I have the option to display this as an icon. This is how I normally have the clusters on my block diagram.
Occasionally, I have to replace a cluster with a different cluster. However, the cluster is replaced with a none-oconised version of the cluster. Thus often the block diagram expans in one direction or another accordingly.
I would like the cluster replacing the actual displayed cluster to adopt the same visual setting (i.e. to appear as an icon).
This actually feels like a bug to me rather than a feature request.
