6 | |
2 | |
2 | |
1 | |
1 |
While playing around with property nodes it is sometimes the case that you set some properties and want to reset the front panel element after some tests
Example:
You place a boolean front panel element and set the property "blinking". Later you decide to remove this property node but the property is still saved in the front panel element.
It's not possible to reset the blinking property with the properties dialog.
I would prefer having an item in the popup menu of the front panel element like "reset properties to default", which resets all properties of this specific element.
Without this feature I have to replace the front panel element with a new one.
