6 | |
2 | |
2 | |
2 | |
1 |
NXG had a neat feature I miss in LabVIEW 20xx and that is resizable nodes for operations like OR, AND, and Add. There are other nodes that could benefit from this too like subtract and multiply, but here is the idea.
I'm aware that the Compound Arithmetic is a resizable node that covers the examples I have here. But often times I will start with just two inputs so I'll use the OR, then later on I'll need to add a node and now I need to replace it with the Compound Arithmetic and then add the other inputs. If the suggestion is to just use Compound Arithmetic, then why even have an OR node?
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
