If a control/indicator has a long label, the local variable takes a lot of space on the block diagram.
It would be nice if local variables can be resized, and
1) when the cursor is moved over the local variable, the full label is displayed just like a tip strip on a control/indicator; or
2) the label of the local variable should be defaulted to the same as the corresponding control/indicator, and can be turned to visible or invisible.
It would also be nice if an enum constant can be resized.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
