| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
When i need an array on the front panel i must be attentive to count the resulting size
(e.g. 15x20 array of integer). It is necessary to count the size manually on the frontpanel!!!
It would be nice to show at mouse position the size of the array that edit on the front panel.
