| User | Kudos |
| 8 | |
| 7 | |
| 4 | |
| 4 | |
| 4 |
I've got some calls to low level VIs that rely on windows system dlls within a larger top level VI. To make that application work on Windows and Linux, I've put conditional disable structures around the dll calls. When I open the top level VI in Linux, I have to click through a bunch of "Find missing file" dialogs for the Windows system dlls. If I cancel through all the dialogs, the VI still compiles and runs correctly in Linux, so the Conditional Disable structures are doing most of what they should, but the dialogs are annoying and can cause problems with automated builds and other hands-off activities. Since the code is inside a conditional disable structure, it seems to me that LabVIEW has all the information in needs to know it shouldn't load that stuff, so it would be great to get rid of these nuisance dialogs.
