Senthil_Prakash
Retain Default Label Position
Status: Already Implemented
 Functionality already available with the Ctrl-T shortcut in Quick Drop
If the Label Position is changed from default position there should be the option to retain the position, because finding the label in a very huge block diagram code is difficult as label is the only identification for the item
Senthil Prakash S
Certified LabVIEW Associate Developer
2 Comments
crossrulz
Knight of NI
Quick Drop already does this!  Open QD with CRTL+SPACE and then use CRTL+T.
Darren
Proven Zealot
Status changed to: Already Implemented
