6 | |
6 | |
3 | |
2 | |
2 |
When reopening a project, the position of the window is retained from the last save of the project, the items in the project tree but not the status of the disclosure rectangles. I usually like to have open the "chassis" and FPGA components as well as my top level software folders, and build definitions. I keep sub-vi folder and hardware module folders closed.
It would be a time saver (and relatively simple) to preserve the status of those personal preferences so that reopening a project takes you to the same state you left it in.
Hopefully this is a moderate reward very low effort request.
